droptheline
- May 2, 2008
- 109
Hi all, I was having troubles getting my 3.0L (89) started when i put it in the water, Bond-o gave me a starting procedure of pumping the gas 3 times then starting @ half throttle- works perfect every time, Thanks, so now when i shut off the boat and the motors hot im having troubles getting it to turn over right away, usally takes 4 or 5 seconds, was wondering if there was a trick for this situation as well??? thank you
