PirateDave
- Jun 16, 2017
- 11
I have a 2003 Larson Cabrio 274, Volvo-Penta 5.7 Gi-C I/O engine.
I have been having a start issue. It began not starting on occasion. Then more often. It would start if I pulled the relay and then put it back. Or if I tapped the relay. And then not again. Or it would start when hot, but not if I let it cool at all. Finally, I can't get it to start at all without jumping 30-87 in the relay socket.
I followed all of the T/S steps outlined by Don S., and everything points to the starter relay. I have power to the 30 plug, power to the 86 when the start key is turned, and I have good ground at 85. Jumping 30 to 87 starters her right up. Just to be sure, I have checked the power at the ignition switch and the neutral safety and all appears to be good. I replaced the relay twice and still not working.
The only thing I can think is that I have the wrong relay? I brought the old relay to several stores to no avail. Finally, Advance Auto Parts had a parts guru who found the same relay (under parts for a 1990 GMC pickup) made by BWC. Five prongs, and we both went over the wiring diagrams on the side of the relays a couple of times. It all looked good. Could there still be a problem with the relay? I have ordered a new relay of the original brand (Omron G8W-1C7T-R-DC12) that should be here in a few days, but am looking for ideas.
