1993 48hp spl Evinrude... When I connect the motor to the battery the starter engages... the key isnt even in the ignition. is this likely to be the starter solenoid ??? I took the ignition switch off and same thing... or is it related to the bad ignition module I removed awaiting a new one to be delivered...... I connected the battery to tilt the motor to check a slight leak on the trim tilt...
