steviecops
- Oct 3, 2003
- 585
Hi<br />I have a 1971 Evinrude 60, (3 cylinder), that I'm trying to get running. The starter turns on the key, but only cranks the engine very slowly. I've cleaned all the terminals and tightened them but it made no difference. I've tried jumping it from the selanoid and even direct from the starter motor, but it will still only crank slowly.<br /><br />I took the starter motor apart and cleaned it all up. The brushes looked fine. When reassembled it would still crank slowly.<br /><br />Is this starter motor shot?<br /><br />I need to get the engine cranking at normal speed in order to do some tests that will tell me whether the engine is worth doing up or not. I don't really want to spend out for a new starter motor just to find that the engine has other issues and isn't worth doing up.<br /><br />Thanks in advance.<br />Steve
