Hi there, hoping to get some help. My 90 merc outboard is stalling randomly. It has a portable gas tank c/w primer bulb.
Initially I found the primer bulb had gone a little soft, so if I squeeze it and restart, it runs for a while then stalls, usually on take off but sometimes in mid throttle. Otherwise it seems to run fine. It's very random. I've replaced the primer bulb, and put a diaphragm kit in the fuel pump complete with all the springs. Checked the plugs and cleaned them although they weren't very dirty.
After some problems starting and running after the fuel pump work, it seemed to run fine, but then did the same thing. It does sound a little different at idle though now, it seems to have developed a bit of putt putt sound that's different from the normal sound.
I'm thinking fuel filter now, any other suggestions???
Any help would be much appreciated!Thanks!!!
