Re: Stainless Prop Question
Listen to Kenny - he makes sense.<br /><br />On a Johnny 50 I took off a standard aluminum prop, 11.50 x 19, last week, and replaced it with a Stiletto 11.75 x 18. Not a huge difference in pitch, or big increase in diameter.<br /><br />I had already squeezed more performance from the alu prop by drilling and cupping it, but I felt I could get more.<br /><br />The Stiletto has transformed the boat! Because of its superior performance, I have now raised the motor which gives increased efficiency (stainless can often run higher than alu). As the motor is more out of the water, the boat is now proportionally heavier at the stern, so I have increased the pressure on my autotabs (not Smart Tabs, but TrimPilots, made here in Malta).This whips the stern up quicker and gives me flatter and faster holeshot.<br /><br />The final result is beyond my expectations. Holeshot is awesome and seems almost immediate, and I can run with the big boys. Wot comes up with no effort. I've lost a couple of mph at the top end, but I run in the sea all the time, and the limiting factor for top speed is often the state of the sea, so that loss doesn't bother me.<br /><br />All this started from just changing prop material.
