thunderroad
- Jun 19, 2005
- 417
69 Mercruiser 160 SN 2497444. On the river yesterday, boat was running fine. We pulled up to a sandbar for a bit. We we left I pushed off until the boat started to drift with the current, lowered the unit, started the engine and put it in gear. We moved a little bit but must have run into a shallower spot. Not realizing exactly what was going on, by instinct I accelerated a little. Not a huge amount, just what I thought I needed to get underway. About the time I realized what must be going on, we got clear of the sand...but we plowed pretty good there for 3-4 seconds.
Nothing seemed wrong at all. We powered at about 3000 rpm for a couple miles, then shut it off and drifted a while. When it was time to go in I powered up and ran up to about 3200. With about 1/2 mile to go, I opened it up. It pulled good until about 3800 then went up to about 4200 almost instantly with no increase in speed. I backed it back down to 3800. Seemed to be pulling fine. Opened it up again and it did the same thing. I first thought maybe I'd spun the prop and wasn't too concerned because it was my "river" prop and I've got a couple others that are better. Then today I had one of those "Oh *****" moments. What if I've spun the coupler instead of the prop? I know all I have to do to find out is slap on another prop and give it a whirl but that's not gonna be possible until early next week and the suspense is killin me. Which is most likely, given the circumstances described?
One variable is that I can't positively swear what position the trim was in at the time. I can't really hear the trim and I don't have a gauge so I usually just trim down until I see the amp gauge bounce a little. Thinkin back...I can't swear that I remember doing that. I THINK the trim was ok because usually when it's trimmed too high it steers hard and pulls a little on the wheel. It wasn't doing any of that.
Any ideas?
Any ideas?
