calledinsick
- Jul 13, 2010
- 160
1995 Sport Jet 90 with Original Black Stator (Serial Numbers 0E145580 THRU 0E151579) converted to Red Stator.
Original Black Stator/wiring (identifiable by 2 yellow, 1 red, and 1 blue wire - just right of center in picture):
Top of flywheel with cover removed. 3 holes for wheel puller:
Wheel Puller attached. Crank forcing bolt down, tap forcing bolt with hammer, tighten forcing bolt, repeat as necessary until flywheel pops loose:
Flywheel removed, orignal black stator. 6 allen bolts holding original stator in place. Unable to see in picture is crankshaft/flywheel key/key-slot on the back side of the shaft.
Black Stator removed (sitting on right), Red Stator in place. Align arrow on Stator for Sport Jet 90 to point to aft. Secure with the 6 Allen bolts/threadlock. Also notice leads from Red Stator are 2 yellow, 1 white/green, 1 green/white.
Inside of flywheel- 6 magnets. Key/Key slot at about 2 o'clock in the picture.
