Javelin 353
- Dec 28, 2003
- 184
1991 70 hp Johnson While using boat last was running and rpm died down to 2500, stopped restarted, same thing , stopped disconnected temp sensor restarted same thing, while limping back at 2500 rpm motor took off then slowed down again the took off again and ran fine rest of day<br /><br />Compression 115 all 3<br />Coils and powerpack new 10/05<br />cleaned all battery connections and coil grounds<br />no visible goo coming from under the fly wheel<br />I am postive this is spark because when at 2500 i hit the choke and the motor died<br />new fuel filter and plugs(champion qljc77 .030)<br /><br />Maybe powerpack again???<br />Lost??
