chris04008
- Aug 19, 2011
- 18
Re: Smoker Craft Rebuild 16.5 Tin
I was looking at those. What is the reason for having two drains for the livewell and why are they so big? There must be a good reason......
Where would you use rigid and where would you use noodles?
I'm noodle proponent #4...but I'd also use some rigid foam boards in certain areas.
Nice project you've got, very similar to my 16' SS. I can see you finishing this and staying under 2k, especially if you are gonna work on the OB yourself, or if it doesn't need anything to run.
I'd make sure those livewell fittings are sealed up well with 3M 5200 before the new deck goes in, just to make sure. They are notorious for leaking and tough to access on the inside.
