Fishhead-1
- Oct 10, 2003
- 110
I bought a complete takeout 5.7 Gxi with sm-dp 1.78 ratio with set of f4 props a year ago complete fresh water half system exhaust gimbal trim pump everything. I run a 5.7 Gsi with same duoprop but a 1.95 ratio with a set of f3 props. The Gxi was on a smaller 21 foot boat, is that a common ratio to be bolted to a sbc engine not a big block? I'm going to build the Gxi as a swing engine as mine has 1600 hours and want to swap it out in two years. I would like to have a swing set of drives ready in the future so my question is are both uppers the same ratio and the lowers are not? Am I looking at $1500 just for a gear set lower to turn it into a 1.95? Do I sell the lower only and buy a used 1.95 ratio that ends up to be a basket case? My current drive is in great shape I'm just thinking down the road. What would you do, thanks
