Hey guys,
Thanks in advance for your help. So yesterday I figured i would go and take my boat out because it has been at least 1-2 months. I had them put it up on the rails to do some cleaning. I figured I would start it up and get it warmed up. Now I have a two battery setup with a switch. The switch was in the off position. So I turned the switch and turned to key and to my astonishment the engine barely turned over almost like it was a dead battery. So I played around with the switch first to 1, 2, and then all again. Each time it seemed like the engine turned over better and faster. Finally the engine turned over enough to start. I am a little puzzled by this and I am unsure if its the starter, battery or both. I did finish cleaning the boat, got it put in the water and took it out. It ran great and started each time. I did get the feeling that at the end the starter did not turn over as robustly as normal. Any ideas on what to check? There is some oxidation on the starter as well. Also my blower took a dump and is not working.
