first post.
2006 Crownline 180 BR 4.3 Merc with alpha drive (not sure 1st or 2nd gen, don't know prop pitch). 48 hours.
Bought used last fall. winterized and summerized by professionals.
Ran great all day Saturday; on the way back to dry dock, it planed as normal, and after a few minutes at about 3500 RPM, I lost power and the RPMs increased. This was repeated and the same result. Temp and oil pressure remained normal. Played with Trim, no difference.
I limped back at 2500 RPM and 10 MPH.
I noticed a course spray, almost a wide, low rooster tail at the stern.
The mechanic has it, just waiting for his diagnosis.
I searched and found a couple of things and was hoping for some input from you-all. Any other ideas?
1. a worn clutch and gear dog
2. lower shift cable malfunction
3. slipped prop hub.
I am not mechanically oriented to repair myself (and the boat is 1.5 hr away), but I would like to sound informed when the mechanic calls.
Thanks
data
Thanks
data
