I have a tandem axle LoadRite trailer with 26" slipper springs. I am in the process of replacing the springs and realized that they are installed differently on each side of the trailer. The dual axle trailer has a front and back bracket that each set of springs connects to and a 7" equalizer in between them they connect to. Should the slipper end of each leaf spring be connected to the equalizer with the eye-hole being connected to the front and/or rear spring hangar brackets? Or should the eye hole of the front spring be connected to the bracket hanger and the eye hole of the rear spring be connected to the equalizer?
Unfortunately, the driver's side was installed one way and the passenger side was installed the other way. Thanks for your help on this one.
Mike
Mike
