I have a 2006 Four Winns H200 with a VP 5.0 GXI and SX-M. Is it possible to replace the sliding sleeve (cone clutch) without removing the outdrive from the boat?
If so could you direct me to a procedure. I have an online service manual that shows upper unit disassembly but it first removes the outdrive from the boat and removing lower unit and mounting in a special holding tool. Then it shows removing the shift assembly (which I have done). Removing the drive shaft nut then lifting the bearing and top gear out to access the cone clutch. I have the nut loose but not removed.
Thanks for any suggestions.
