fairshopperguy27
- Aug 22, 2012
- 127
I just acquired a 1989 Tiara Pursuit that has a Yamaha 200hp with 384 original hours. The original owner told me he fogged the Cylinders 7-8 yrs ago when he parked it. He also drained the fuel cell. Well It's time to wake it up! A few questions I have are: #1) should I rebuild the carbs before firing it off? #2) should I shoot some type of lube into the cylinders as it sits and let it soak or should I go to the great lenghts of unmounting the motor to lay it down so the pistons are up down while shooting with lube? #3) should I just replace the oil pump now? I just saw the same year parts motor on CL burnt up because of pump failure and I don't want that to happen to this one.
Anything else I should do? Im Planning on doing sparkplugs and lowerunit oil, water pump.
