nospark1196
- Aug 6, 2003
- 32
O.K. -> I just did all of the following:<br /> 1)Carb. kit w/float needle and gaskets<br /> 2) Carbs adjusted 1 1/2 turns out from<br /> a slightly seated position.<br /> 3)Seafoam in the tank and thru the carbs<br /> <br /> -> The motor, which is a '02 50hp Tracker<br /> idles fine and runs pretty darn good, <br /> exept for smoke @ start up and when I <br /> give it gas to get out of the "hole".<br /> <br /> -> When I checked the plugs this evening,<br /> they were wet w/oil&gas and they looked<br /> black.<br /><br /> == My question is----> Should they be dry?<br /> I do not want to run<br /> it too lean.<br /> (detonation)<br /><br /> Thanks,<br /> <br /> Nospark
