I have a 2008 Mercruiser V6 190 HP Engine. I was setting up to change my oil and put the muffs on the outdrive and turned the water on. I started the engine and water started pouring out the engine and i heard a metal noise hit the bottom of my boat. I looked and found a round plug popped out. Turned water and engine off found where it went and tapped it back in. I restarted everything ran engine did what i had to do and all was good. Well i called my dealer and he told me it was a freeze plug that had popped out because my block froze. WHAT???!!! I said. I thought i drained everything but found that my lil blue drain plug on that side was clogged a lil stuck wire in and all the water came pouring out. So i did accidentally leave it full of water. They told me i need to change the freeze plug but the problem is i cannot get it out it is in there very tight and in a hard to get to spot. My question is do i need to worry about anything r just hit the water without a worry. No water in oil and no water leaking could i have cracks? but i have only ran engine about 20 minutes since then.What do i do please help!! Thanks
