Re: Shortening Bimini Top
If you went straight down from its current windshield location would that be too much? or even if you moved it toward the stern an inch or two would that work? you could easily bow it out a bit to make it clear the glass when folded they usually make them with 4 inches of allowance per side 2in or 2out. Otherwise I would say cut the ploe that attaches to the windshield as much as you can and the rear poles and see what that nets you, Being on a 45 deg you will only get about half the drop that you cut off. I say better a bit too tall than having to duck under every time. It gets old quick if you are doing alot of watersports etc. where you arent just sitting/standing at the helm the whole time. Remove the rear pole bolts and the windshield mount bolts, leave it all togather and get some help for a few and hold it on the fiberglass(with a rag under it) and see if it will work for you, if not you will need to have it off anyway to do any cutting. Also the hinged or flat mounts you would need will raise it almost an inch as well. If you have a flat area you could reuse the ones on the windshield(unless they are rivited on) which I doubt, then just fill the holes with alum silicone and then you wont have to worry about the cover stressing on the windshield mounts.
