Shift shaft help!!
tonysp
I have an 82" 40hp thunderbolt. While changing the impeller I broke this part of the shift shaft while reinstalling g the lower unit. Seems I didn't line shift shaft properly before tightening. I see the part number "75104A8" for the shaft assembly but not this part separately. What is the name of this part of the shift shaft and can it be bought without the shaft. Any help would be appreciated so I don't keep going bonkers looming for it.
thomas15
Sorry, maybe someone else can help but the S/N comes up blank for me
tonysp
I know its weird. I've had a couple places have the same issue then an old Marina with no computers found it easily. LoL. Thanks for your effort.
Anyone else??
Faztbullet
Sold only as a assembly..Check the block real good as there is a tab cast on it above this linkage and when installed wrong it is broke off leaving small hole in block
tonysp
I'll check that . is the powerhead need to be removed to change the shift shaft? Not much info on this subject I could find.
tonysp
I saw how close it was to the block. I'll check it. A pricey mistake. Can't seem to find a used one anywhere.
