1984 Mercury 25XD. Trying to remove lower unit. Seloc manual says to "remove the shift lever coupler located in the bottom cowling behind the carburetor". I have looked under, on top of, sideways, and do not see this coupler. If it is under the carburetor, how in the name of common sense do you get to it?? Or am I looking in the wrong place. My engine parts catalog does not even show this coupler. Can anyone help me on this. It is the older style unit, it does NOT have the rubber plug on the side to disconnect the linkage. I am just confused as to how to disconnect the shifter rod so I can pull off the lower unit. Maybe I'm looking at the wrong thing, but if it is under the carburetor in the center of the cowling, don't know how you would even get to it. Hire a **** ant with a set of needle nose pliers I guess!!!!<br />Thanks for any help!
