PeteK
- May 22, 2017
- 10
Hello to all,
Learning as I go and could use some guidance. Not sure about shift interrupt/neutral lock etc. Have two switches that appear to be shift interrupts. One is on the valve cover and looks to be incomplete. The other is on the inside transom plate/shift plate and is electrically disconnected. Looks to me like the valve cover switch was added to replace the transom switch which was abandoned.
Engine is Mercruiser 3.0 circa 1987
Sterndrive is MC- 1
I've got wiring diagrams and have a basic understanding of the concept but need to fill in some big gaps like should't there be a lever arm and also a cable attached on the valve cover switch. Also where does the cable come from/to etc.
Not asking for a step by step hand hold but a hint or a past thread would be a big help.
Thank you fellow boaters
PeteK
Sterndrive is MC- 1
PeteK
