Re: serial # crisis what is it; when was it born
From the look of the engines they're inline 4 cylinder Mercruisers (may not be brand name, might be converted car engines or something) attached to MC-1 pre alpha sterndrives.
Assuming the drives and engines are the originals, that means the drives probably have a 1.98:1 gear ratio.
The engines themselves could be any number of models, including the "470" that people seem to hate a lot. Perhaps 140-170 horsepower each.
Like Don says, recheck the numbers. Check the serials on the sterndrives, they'll tell you the approximate year of manufacture and you can look at the U-joint yoke to find a letter stamp that'll confirm the gear ratio.
Usually Mercruiser put a sticker on the valve covers giving the model, but it looks like those have been repainted. Check the carbs for a metal tag with model info.
If the engines run (and aren't 470s) there are plenty of parts available and even replacement engines that use the same mounts.
What are you trying to do with these?
Erik
