tmcalavy
Re: 1956? 12hp, Sea King
Hey Pete...another Texican on the board. Your Sea King was made by OMC/Evinrude/Johnson by their Gale Mfg. division for Monkey Wards. There should be a plate on the front of the transom clamp with a series of numbers, and GG in there somewhere. If yours is a 56, those numbers will be reversed in the string, like 65GGXXXX. Any good OMC dealer can get parts for it, cause it uses the same parts as Evinrude/Johnsons of that era, points/coils/condensors/impellers, etc. The fuel pump diaphragm (rubber) is probably shot...new pump costs less than $50, especially on the auction sites. Probably need to pull the carb, soak it in cleaner, blow it out with compressed air and reassemble/install. It uses a Champion J6C or J4C plug gapped at .030, points are set at .020 and fuel/oil mix ratio is 16:1...about 1/2 pint oil per gallon. Let us know how it goes...somewhere on the board is post called "awakening a sleeping outboard," has most of the info you will need to get it running sweetly again.
