Racingman24
- Jun 23, 2009
- 126
Ok, so....I finally got off my stubborn horse and switched over to Interlux paint from Rusto....and wow the differences. Unreal. I shoulda just listened from the start....but I'll talk about that later.
Anyway, I got the first coat today on, and it looked great [still does technically]. I sanded it down to prep for the second coat tomorrow. I used 320 grit [just as the can of 'lux says] stuck to a DA. Got it all smoothed down and ready for tomorrow morning. [Not that it wasn't smooth to begin with....]
My question is, is the DA taking off too much material? In some areas I can tell that I'm getting down to the layer below it, some of which I believe is caused by not enough paint to start with, as I'm still working on that perfect blend of light coat with proper coverage and sheen but not so heavy it runs.
Would just going after it with red scotchbrite be ok in between coats, as long as there aren't brush marks to knock down? I plan on hopefully having it buffed and such when I'm done so I want to make sure there is enough paint on there so it doesn't get burned through.
I guess I'm just wondering what everyone else is using in between coats to prep for the next one.
And the second...somewhat simpler question....
I've finally got most things down with the paint to make it look really really nice when it's dry...the one thing I'm still struggling with is visible overlapping.
What I mean by this, is that when the paint is dry, you can see where I overlapped from one area to the next as I was moving along. It's not much, an inch or two, but I see it and it's bother some to me.
Part of me thinks this is my own fault from going to light with the paint early on. I have read lots and lots on here to do multiple light coats instead of 1 or 2 heavy coats, and I'm wondering if I'm doing it too light. Therefore when I overlap, I'm getting the correct amount of paint and that's where it looks different.
Should I be "loading" the roller before I start? Not to the point where it's dripping, but so it has some paint in the core so I'm not picking up paint as I go? This is the one and only "problem" I haven't been able to solve on my own or with info from here, and I just don't know what to do about it.
Thank you for reading my 17 page post!
