Hi guys, I am working on a 1964 johnson CD-21A, first can any one tell me what the A stands for? When I got this motor it was stuck from sitting(?) I purchased a bunch of motors after the local small engine guy died. I put some deep creep in the cylinders and let it set for a few weeks then broke it free by turning the flywheel nut with a wrench gently back and forth till it turned freely. It took me a while to get to it, but I tested the compression and had 120 one the upper cly and 90 on the lower. I know this is quite a difference between the two but after spending half my life reading posts on here, I figured it may be a stuck ring. So I thought i would get it running and do a decarb and check again. I had the coils and points amongst the stuff I had bought and I put new plug wires on it and got great spark. I had a carb kit and did that too. I put it in a garbage can of water and got it to start, it ran a few seconds and quit, and then wouldn't start. So I pulled the plugs and found they were fouled with a rusty colored goop. So I cleaned them and tried again, same thing. Then I was looking at the oil return hose (I have a parts manual for a ev fisherman 5512 & 5513) and saw it had cracks in it that were oozing the same brown crud. I took it off and some more came out especially after I put my drill on the flywheel nut and spun it a few times. My question to you is what is this crud? and how do I clean it out of the interior of the motor? Is there any way i could fill up the crankcase with say varsol and then drain it or is a complete tear down necessary? thanks guys
