I have three screws, on each side, for a total of six. These screws are attaching a stainless support arm or strut to the back lower part of the transom... the support arm is supporting the extended swim step. These screws are underwater and the boat is moored most of the time...
This boat is a 2004 Regal 2665. Problem is, there is rust streaks running
from the inside of the engine room where these screws penetrate...
I am going to remove the screws, drill, clean and seal the holes and replace the screws with the boat out of the water...... but not sure how to clean the rust off... this is a rough surface with no gel coat... it is in the enigine room and extremely hard to get to, unless you are a smurph...
Any smurph's out there?
Should I use a wire brush, or wheel...?
any help is appreciated.
