Rochester 2bbl carb compatability...
Oshkosh1
Ensign
I was out and found a "mans" rummage sale, so I stopped.
I found an old, in good condition Rochester 2bbl carb(with two adjusting screws and automatic choke)which looks identical to the one on my boat.
So my questions are:
1. Can I rebuild this and keep it for a spare?
2. If so...is there a marine specific kit?
Thanks in advance.
achris
More fish than mountain goat
Re: Rochester 2bbl carb compatability...
What is the model of the carb? If it's one of the marine carbs, then you can rebuild and have as a spare... There is no specific 'marine' gasket kit.... Any gasket kit for that carb will do the job...
Oshkosh1
Ensign
I couldn't find a tag on it. There's a number stamped in...7008597, I suspect this is for automobile application. Oh well...$5 spent. If nothing else, I'll use it as a practice piece and rebuild it to get a feel for how these things work. It has a "port" on the opposite side of the two mixture screws and the fuel line enters through what would be the forward face of the bowl, rather than the port side as my current carb is set up.
achris
.... It has a "port" on the opposite side of the two mixture screws ....
That'll be the vacuum advance port, so it's definitely an automotive carb...
Oshkosh1
Ensign
Any way to "convert" it for marine use?
Don S
It's a very old early 50's carb. Has to be automotive, marine carbs didn't even exist back then.
Bet it has the vent on the top too.
