tmiller4090
- Sep 15, 2002
- 30
ok, heres the situation,I have a 1988 85hp force that ran perfectly,I changed the gear lube and misstook the shift pivot screw for the drain.heres what I did to fix it.1- bought a manual- then i dissambled the gear housing down to the pinion gear,took the propeller shaft out ,then i dropped the entire lower unit from the motor and removed the upper and lower water pump housing from here i was able to retrive the shift cradle and reinstall it according to my manual.then I reassembled everything.I havent started the motor yet but I put it in forward and the prop locks one way and spins freely the other way.in neutral the prop spins freely both ways.in reverse it will lock one way but if much pressure is applied it breaks free and sound like the gears are slipping in the gearcase.I don't want to start the motor in fear that I may ruin the entire lower unit. all the gears looked good in the gearcase so i must have overlooked something. any suggestions?----Troy
