I started my 1985 Evinrude VRO 140 today (out of water) after it had not been operated in 3 years.
I did the following prep:
1) Siphoned out all the old fuel and filled the tank with 10 gallons fresh. I siphoned the fuel out using the fuel line outlet on the transom - very handy!
2) Checked fuel filter.
3) Lubed and soaked the cylinders with TCW-3, and made sure the flywheel turned freely.
4) Cleaned the spark plugs.
QUESTION #1: Before the first start attempt, when I pumped the fuel line bulb (until it was firm) I noticed (the engine cover was off) fuel seep out of what I believe is the fuel pump. The fuel came out of a seam where two pieces of plastic come together.
I have attached an image with an arrow pointing to where the fuel seeped out. It came from the seam where the two plastic pieces with the visible screws there come together. Not sure if there is or should be a gasket in there or not.
My friend who was helping me thinks this was caused by the abnormal pressure I put on the fuel line while pumping the bulb hard - he said he noticed that there was not any seepage from the same spot, or anywhere, while the engine was running. I am no Arnold Schwarzenegger or anything, but I could definitely see that I may have pumped the bulb too hard.
I need to verify this. It does not seem normal that fuel would would leak out anywhere when I pump the bulb, and I am concerned that this could be a bad gasket or part. Any ideas?
------------------On to first start attempt-------------
I hooked up a flusher, turned on the water and proceeded to try the first start.
On the third try or so after pumping the gas and applying the choke she turned over, sputtered and quit; then she turned and ran after a few more tries.
I ran the engine for about 20 seconds or so and then shut it down after noticing there was no water coming out of the engine - suspecting the water pump was not working.
QUESTION #2
Should the water pump start pumping water immediately on starting, or does it take a bit? Does the engine have to warm up before the water pump engages? I expected the water to start pumping out of the engine immediately. Do outboards have thermostats or something to engage the water pumps?
Thank you.
QUESTION #2
Thank you.
