billbayliner
- Jun 30, 2006
- 553
Hello all: Well I have finished resealing my 1996 Alpha 1 gen 2 drive. Not fully as did not have the tools required to do complete job. Also changed the impeller and plate.
pressure Tested 15 psi.... Passed
Vaccuum Tested 6 inches water column .... Passed
My only concern is the water pump face seal. I did not have the water pump face seal tool. What I did is insert the lower lip of the seal in to the water pump housing, lube the heck out of it, and carefully slide the housing with the face seal already inserted into it, down the shaft and bolted the housing in place.
This is of course not how the manual said to do it but I did not have the tool. When I turn the shaft, the seal also turns with the shaft.
does anyone think this Is this going to be an issue?
Thanks for all your help
BILL
BILL
