Re: Replacing Wood Transom with Aluminum
The strength isn't an issue, it can easily be light and strong enough using Aluminum, you just don't need a thick plate, a thinner skin can be separated by some square tubing, my 90hp is mounted that way.
The wood is used for a few reasons, its light, easy to work with, readily available, dampens vibration, makes a very good clamping surface, is low in cost, strong for its weight and for the most part very easy to replace if it ever needs to be.
When left open so it can easily dry out the wood on aluminum transom normally lasts for a decade or two, not bad for less than $10.00 worth of wood.
One of my boats has a 1/4" aluminum plate with 1/2 PT ply on both side for the kicker (9.9) mount, another one has just aluminum plate bent and welded. They both work fine, I just need to watch the aluminum only bracket to make sure the transom clamps don't come loose, because it doesn't take much for the motor to lose its grip on the aluminum and slide up and off. Wood gives a much better clamping surface, but its possibly only a 20 year fix.
