I recently installed model B144 Boyesen Reeds in my Evinrude 115hp V4 1978 model (model number 115893c. I believe this is a Crossflow type).
I had read in several places that a replacement jets (or resizing jets) may be needed. I also found a few places that said it didn't matter.
I'm certain some engines it doesnt matter but for my carby engine im sure it does. Indeed, after the installation I switched the engine one and it was popping/backfiring at idle so I immediately switched it off.
The instructions for the reed installation says:
IMPORTANT-CARBURETED ENGINES ONLY: STEP 10 MUST BE FOLLOWED OR THE WARRANTY IS VOIDED. USE THE PROCEDURE SPECIFIED FOR YOUR TYPE OF ENGINE. 10. BACKFIRING (a lean condition in the idle circuit, sometimes described as a lean pop, coughing, or sneezing), will cause REED DAMAGE. This MUST be prevented by one of the following methods: A. Carburetors with IDLE AIR JETS controlling idle: EVINRUDE and JOHNSON engines - downsize idle air jets 5 sizes {5 thousandths of an inch}. MERCURY and MARINER engines - downsize idle air jets 2 sizes (4 thousandths of an inch). B. Carburetors with LOW-SPEED FUEL JETS controlling idle: Increase 2 sizes {2 thousandths of an inch}. C. Carburetors with IDLE MIXTURE SCREWS: Richen by turning counterclockwise 112 to 1 turn out more than stock setting. D. On some worn or modified engines, no adjustment will be necessary.
Problem is, I dont know what sort of carburetor my engine has. Can anyone help me out here? I believe the jets are fuel jets so I can simply drill out the jet to get it to the right spec, but again, im not sure about this. I would much prefer to drill out the jets as I have spare ones from a different set of carbys I have lying around.
Also, does anyone know which jet will need to be resized? I dont know what is looks like if someone could please point it out to me in the pic below that would be greatly appreciated.
EDIT:
I have successfully installed the jets now. For those of you who are reading this thread to find out what you need to do, I have summarised the main points below.
- Below information is for a 1978 Evinrude 115hp V4 (Crossflow) Model: 115893C or 115893
- Below information is for installing Boyesen aftermarket reed valves (model B144)
- There are 2 idle jets per carburetor (4 orifices/jets in total)
- They are FUEL orifices, so when installed Boyesen Reeds you need to go UP 2 sizes
- Stock PORT orifices are #28. Stock S/board orifices are #27.
- Replace the PORT orifices with #30. Replace the s/board orifices with #29
- Port orifices are the ones on the left when looking at the bow
Hope the above helps!
EDIT:
