Re: Repitching Rude 8 1/2" X 9" aluminum prop
I have an after market Intertec manual.I skimmed through to see if I coiuld find any obvious difference between the 7.5 and 8.The only thing I noticed was The 8 with a powerpack marked CDL has a device to limit rpm at 6,200
and the 8s reeds have 3 retaining screws instead of 2.
Also checked NAPA parts catalog it appears the 8 uses a different power pack than the 7.5.As none is listed for the 8.
Not unusual for similar motors to develope different hp ratings by using subtle changes in induction etc. some as simple as a throttle stop.
Also not unusual for the higher hp to be rated at higher rpm. ie::
the 9.9 and 15 9.9 5,000 to 6,000 15 5,500 to 7,000 of course the 15 has
more changes than a throttle stop to achieve its output.
Stick with the 50:1 mostly to combat corrosion during storage and little use times.Sounds like you got it pretty well dialed in.You could raise the vertical height to see if you can squeeze a little more out of it just be sure it pumps water.
