LakeTravisAlpha1
- Mar 15, 2016
- 33
My 1995 Wellcraft Excel 19 SX w/ 3.0 Mercruiser Alpha One LX has at least one leak where the 3/8" vent hose goes into the plastic fuel tank. I'd pull the tank and replace it, however this boat has been discontinued and the belly tank that lays under the floor has so far been impossible to find online. A new tank would have to be specific to my boat and be an exact replacement of whats there as there is zero space between the stringers and it has a V bottom that lays in the hull. So my only alternative is to fix what I have.
The boat has always been 'gassy' and I strongly suspected a leak somewhere. When I topped the tank off with fuel I noticed a wet circle around the vent hose fitting slowly growing larger. The vent hose has a silver metal cube or square fitting on the end that apparently attaches to a thin, silver, hex shaped collar on the tank. Below that collar comes the seepage.
Do I detach the hose from the box end and :
a. Unscrew that box shape fitting from the collar, then unscrew the collar from the tank?
b. Leave the box end attached and try and get an adjustable crescent wrench on the thin collar?
c. Does the thin silver collar on the tank screw into a plate in the tank or thread into the plastic tank itself?
I was hoping to unscrew the silver collar from whatever it's threaded to and applying a gas retardant sealant like Permatex under it.
Is this possible?
Is this possible?
