Removing and replacing voltage regulator Johnson 150 ocean pro
Bob W.
Need to remove voltage regulator. Having difficulty locating end of ring terminal red wire. It appears to go somewhere under the flywheel. How do I disconnect that red ring wire? Is it necessary to remove the flywheel?
You might tell us the year of the motor, or the model number. A lot of models have the VR connected to the starter solenoid or a terminal block.
Bob W.
Thank you. It's a model J150SLED. When you mention VR are you referring to the red wire? What does VR mean?
Bob W.
Thanks Jakedaawg, Right now I'm considering that maybe it is not the VR after all. Perhaps it is the dash-mounted volt meter. When the ignition key is on without the motor running should a good voltmeter register approximately 12 volts? Mine goes way high on the scale, above the range of the meter and the needle just vibrates. Does this indicate a possibly faulty voltmeter and not the need to replace the VR? I first noticed the voltmeter at this extremely high end of the scale while running the engine. All the battery terminals are tight, all fuses are good, all electrical components seem ok. Battery is fully charged and has correct water level. Thanks again for your help.
