Reed valves work like one way valves. As the piston goes down in the cylinder, it create a vacuum. That vacuum pulls in both air and fuel mixture and the reed valve fingers are sucked open. Then as the piston starts back up in the cylinder, it creates a pressure and that forces the reed fingers closed again getting ready for the spark. So those reed fingers do two things and they work very well for what they actually are.
