1900clueless
- Mar 13, 2016
- 18
While chasing a (How to test Rectifier/ Regulator) in this forum. Disconnect Gray wire from Tack, and connect to Y/G wire from Starter if Tack works R/R is bad. While trying this test, I disconnected G wire,. started motor and the Tack worked with out connecting to Y/G wire .Connecting to Y/G had no effect ether way Gas and water gauges continue to not work. Do I need a new R/R or is something else going on?? 1996 Johnson V4 115hp
