Re: port 305 stalls on shift. YouTube video attached.
infy
It starts instantly. Revs up no problem. But as soon as you touch F or R it stalls instantly. No hesitation.. no effort.
I'm suspecting a bad neutral safety switch. Or does the shift interrupt need to be tuned?
I know the previous owner just replaced the distributor cap and spark plug wires. Could an error in the wire sequence cause this?
infy
Someone suggested checking the shift plate. Everything seems ok. Followed the wiring harness and nothing stood out.
CV16
I would think the shift interrupter is where your problem is. Look on youtube, plenty of videos to show how it should work.
Bt Doctur
lower shift cable is bad or corrosion in the shift components in the drive
infy
Thanks! I'm going to do a quick test before having that lower shift cable replaced. Next time I'm out there, I'll disable the shift interruptor switch circuit. Then start the port engine in open water and shift it in to gear. If it shifts and I have thrust, I'll know it's not a short or a problem elsewhere.
Bt Doctur
The interupter switch assembly MUST NOT MOVE going into gear, if it moved, the lower cable is bad or there is corrosion present.
