Re: Nav light not working?
I have the same problem on my new purchased 1994 Larson with outboard motor. The previous owner disconnected some of the lights. I can shoot power to the wiring with a power probe and the lights operate just fine, however when hooked up to the switch, they do not turn on. I noticed that without the light wiring hooked up to the switch, and just the power source hooked up....the switch will supply power in both nav and anchor positions. When the wires (light sources) are hooked up the witch will supply a ground signal, therefore not turning on the lights....I have purchased and installed a new switch and get the same results. The sitch wiring seems pretty simple...middle prong=12 volts source and the the two outside prongs for the nav and anchor lights with diode in the middle. What else could it be?
