IWishMyBoatRan
- Apr 30, 2013
- 81
Hi! I have a 1971 60 H.P. Evinrude Model 60173 E and I'm a newbie with outboards that don't have power tilt/trim.
When the outboard is up, there is a lock that holds it up. There is a pin/rod that I have in the third hole that stays there.
When I let the outboard down, it rests against that rod/pin. Now, when I'm not running the engine, I can just raise and lower the outboard by hand and put it back in the lock position. But out on the water, if I run it, and stop the engine, I walk to the back and cannot raise it. I have to get out of the water, get to the back of the boat, raise the outboard slightly and pull that pin/rod out of the hole, then raise the outboard into the lock position. Its like the outboard is grabbing onto that pin/rod and not letting go of it. From what other people have said, I should just be able to walk to the back of the boat and raise my outboard up so I don't break anything when approaching to bank/dock/etc --- Now, I do have another thread saying it won't go into neutral, but forward and reverse works. Could the fact its not going into neutral make it stay locked? Any "levers" back by the outboard that I have to pull first before raising the outboard?
