Re: Quicksilver control
push in on button thats neutral button and shift forward all the way now the button will come out pretty easy before i wrote this i went to my boat and tryed it and it came out there is a 11/16 in. brass hex bolt remove and handle will come off when you put it back on make sure to lube it well thats the inside and the hex bolt to torque to 150 lbs if you can find it use loctite 242 to lube
I found this in another thread on here so search Quicksilver 3000 disassembly/ trim switch. That thread should give you all the info you are looking for i hope this helps.
