Hello all I have a 74 50HP Johnson 50ESL74M,
I just rebuilt carbs, installed new ignition coils etc. and wanted to check my timing. Couple of questions about Joe Reeves method.
1. The procedure says "have the s/plugs out, and have the throttle at full" and later says "Crank the engine over and set the spark advance to 4? less than what the engine calls for".
Question: I can't crank my engine with the throttle at full. It needs to be started with the idle leaver up and the throttle in neutral" What do I do?
2. My motor calls for 19 degrees timing at WOT, primary pickup location C (Center of the mark on the cam) and notes to loosen the clamp on the throttle shaft and move the roller to meet the cam.
Question: I'm a little confused here. Am I mixing up a lync and sync with setting the timing up at WOT or is it the same thing? I have not used a timing light before. Do I adjust the timing arm until I get 14 degrees on the light.
3. I have not adjusted the low speed needle valve yet. I was going to do it in the lake this weekend. I did start it up on muffs with the needles lightly seated and backed out 1 and 1/2 turns. I only ran it for about 10 seconds but it appeared to stay running with very minimal throttle. Should I fine tune the idle before looking at the timing.
I do have a manual but not an OEM version. It covers a range of johnson motors. So far it has been pretty good but it is confusing when it comes to setting up timing.
Thanks for looking at my long winded post.
Thanks for your help.
