Have 85 50hp outboard that has been snapping keys. Replaced with new coils (old ones were cracked) and got some extra keys but believe they were crappy non case hardened keys. Ordered three oem ones. Seems to be still happening. It starts and runs fine but on shutdown when the motor stops and gives a lil compression kickback like engines do, it seems to shear the halfmoon part off. I'm wondering if this might be something with ignition system/timing? Tune up kit i can get for $70 but really dont want to. I believe buddy lapped the shaft and crank alittle but not sure how well he did and if he torque the flywheel down enough, looks like it could be lapped better. Bringing a torque wrench home from work to get it to 100 ftlbs. So would lapping crank and torque be the problem or ignition/timing issues? Seems to be only when engine comes to stop.
Thanks
Mike
Thanks
Mike
