85stratosman
- Oct 8, 2009
- 14
I am checking out this 89 johnson GT 150 VRO to put on my 18ft stratos bass boat because I am over rated right now with the Mariner 175 and can not fish tournaments. The questions I have are as follow, I run a compression check and all cylinders except for #5 checked out right at 100 and #5 checked out at 90, I read on here that for those motors that compression is good but compared to my Mariner having 120 on all cylinders this makes me kinda skeptical. The motor has sat up for 5 years and not been run it took me about ten minutes hooking good pre mixed gas and oil up to the motor and cleaning the plugs and a good battery to get it to fire up. It sounds strong and has a little miss at idle. Now the cooling system is set up different from the Mariner which I am use to. The johnsons cooling system just has a nipple coming out of the block straight to the pee hole I cleaned the dirt dobbers out and to my surprise the impeller still had a strong pump for sitting up so long, but my concern on that is with the muffs on the water coming out of the pee tube is still cold it never warms up like on the mariner. Is this normal for the cooling and is the compression really ok. Any comments would be greatly appreciated. Thanks
