I am still having issues with my motor coughing at mid throttle and high throttle too. Also, seems to not want to decide weather it wants to idle without stalling or not. I am sure my carb is clean and she is getting fuel. so, I started to suspect the ignition. As far as I can tell using the manual, the timing is fine. I got 250 ohms for resistance on the charging coil, which is in spec, but when I check the secondary resistance between the two spark plug ends, I get nothing.
Question is if the coil is bad and showing no resistance, should I still be able to start and run the motor?
