Re: Question for nautiJohn
snohomishbaddawg;<br /><br />You couldn't pick a shorter name? Just kidding!<br /><br />First, the ST1290-60 will be enough for just about any engine you use on this boat. Kepp in mind that you can adjsut the pressure to suite your needs.<br /><br />I would like to know what you have on the boat (motor) now, and if I can be nosey, why you intend to change the motor. Not that the yamaha 90 isn't a good choice, as it is, but I am curious as to why you are repowering.<br /><br />I believe there is a web site for Arima owners as I had a customer call not too long ago who said that is where he came up with our name. His results and others were good. <br /><br />As for space requirements, you will need 11.5" in width across the bottom edge of the transom to mount the trim plate (if you go to the MoBster Tabs you can get away with 10"), and a space 3/4" by 2" above the center (10.5") of the plate to mount the top bracket. Go to our web site and down load the instructions
www.NauticusInc.com just to be clear. <br /><br />The plate size for the ST1290 series is 12"wide x 9" deep and the MoBster Tabs ("Steal the Hole") MT1080 is 10" wide by 9" deep but tappered to 8" wide at the trailing edge.<br /><br />I can not tell you to re-prop before you re-power because the characteristics from one engine to another are vastly different. That is why i would like to know what you have now and why you want to re-power.
