kjspylite
- Jul 2, 2010
- 37
motor: 1989 Mariner 75 HP 3 cyl.
clean carbs, compression is good, timing is good, idle mixture screws 1.5 turns out
I am trying to diagnose a bogging, no accelerration problem. Idles fine and revs fine on muffs. Idles fine in water, but has zero acceleration. It will only move forward at barely above idle speed. It never surges or acts like it going to accelerate.
I first wanted to diagnose it as a fuel or ignition problem so I built a DVA adapter from instruction on this site and tested per CDI's manual.
I took DVA measurements while the motor was running, ON THE MUFFS, at idle speed. Everything checked out OK.
Here is my question: Can I trust these readings? Does good voltage out of stator switch box on the muffs translate to good voltage on the water under a load? Do I need to perform the DVA test in the water while trying to accelerate?
I would like to know my DVA test results are accurate so I can concentrate on finding the fuel issue. Thanks in advance.
