I'm installing a new waterpump kit on my 1987 8hp evinrude model # BE8BACUD. When I removed the foot i notice there was no rubber oring on the drive shaft. And no notch for one ether. On bigger motors there has always been one. Does this model not use the rubber oring on the tip of the drive shaft right below the splines? And the impeller key was plastic. In the kit the impeller key is stainless steel. Should I use the original plastic key or the stainless steel key? Thanks allot for your expertise.....
