BlackKnight755
- Jul 3, 2001
- 67
I have a 1993 Mercury 2.5 EFI 200 horsepower engine and when you crank it up I dont get a very strong or steady stream of water coming out of the back of the engine. At idle, the stream of water almost seems to have bubbles in it (kind of spits it out), but at any higher RPM than 1000 it evens up and gets strong and steady. Out of the water with the muffs on it, it may take as long as 1 to 1 1/2 minutes for any water to come out of the tube at the back and it has steam coming from the water when it does start to flow, even when the temp outside is in the 80's. I changed the water pump in June of 2003 and it doesn't seem to have any heat problems. I don't have a water pressure gauge, but I think that its time to invest in one.<br /><br />The engine runs as smooth as silk through the whole RPM range from idle all the way through. It has been taken care of, and I just dont want to mess anything up if I can help it.<br /><br />Thanks,<br />BK
